Rad Power Bikes Chat => Service & Repair => Topic started by: Therooke on May 08, 2022, 07:47:26 PM
Title: New runner. Odd sound
Post by: Therooke on May 08, 2022, 07:47:26 PM
Hi there. Had my bike for just over a month and noticed a sound in the rear.  Nothing is rubbing and it still does it when I remove the rear break.  It's a high pitched squeak. Not really a grinding sound at all.  It does it even with the slightest movement even.  I can rock the rear wheel like a DJ and it does it even.  At first I thought it was just the break rubbing after I slightly adjusted the free movement at the handle.  But it wasn't that at all.  Do E bikes normally make noise or do they spin quiet?  Should I be at all concerned?
Title: Re: New runner. Odd sound
Post by: Radio Runner on May 08, 2022, 10:16:42 PM
Sometimes the rubber hub bearing seals can do that. Hard to diagnose online but that my 1st idea.
Post by: Therooke on May 08, 2022, 11:01:23 PM
It is a squeaky rubber sound. I was going to say that in my post. But the as the tire is not rubbing on anything I didn't say that.  Is it normal?  Or should they have lube on them so they don't tear or melt from the friction?  Thanks
Post by: JimInPT on May 09, 2022, 05:04:47 PM
This might be the same squeak-squeak problem I had with the front wheel of my MiniST - Rad support helped me diagnose and fix it over the phone.  It correlated with wheel rotation but not application of the brake, or not.
As Radio Runner said, there is a rubber bearing seal on the outside of the wheel to keep dust and gunk out of the wheel bearing - it lightly rides on the brake disc as I recall and looks like a little black coolie hat, sort of truncated-conical.  Rad had me apply a tiny bit of light oil under the lip of that seal and rotate the tire to distribute the oil - problem solved and hasn't returned!
Just a very tiny bit of oil is all it takes, the smallest amount you can apply with a fingertip - you don't want to get excess oil near your brake system.
Hope this does the trick for you.
Post by: Therooke on May 10, 2022, 07:34:53 PM
Thanks all.  I'll give that a whirl and see if it kills the noise
