Discussions by Rad Model => RadWagon => Topic started by: lowspark1974 on May 15, 2023, 07:10:16 AM
Title: First ride of the year battery dead
Post by: lowspark1974 on May 15, 2023, 07:10:16 AM
Brought my battery in last Winter had a sitting in a nice warm spot. Then make sure it was all charged up before I took my 1st ride of the year and now the bike won't register the. Battery and I get this when it's charging. Please see attached photo any help would be nice and I only see this when I hold down the little white button off to the charging scale on the battery. Looking. At? The battery the way the photos. Taken? It's 3 green lights and one red light.
Title: Re: First ride of the year battery dead
Post by: lowspark1974 on May 15, 2023, 07:12:34 AM
2nd photo.
Post by: handlebar on May 15, 2023, 10:00:41 AM
It looks as if you're not getting electrical continuity between the battery and the bike. Maybe a little corrosion over the winter.
Post by: lowspark1974 on May 15, 2023, 10:56:24 AM
So do all those lights look correct?
Post by: handlebar on May 15, 2023, 12:32:33 PM
Quote from: lowspark1974 on May 15, 2023, 10:56:24 AM
Yes. That's why I think the problem is not in the battery. It happened to me when I forgot to turn the key on.
Post by: lowspark1974 on May 15, 2023, 12:54:12 PM
I'm thinking of a little scrub with a wire brush on the battery and bike maybe?
Post by: handlebar on May 15, 2023, 01:30:44 PM
Quote from: lowspark1974 on May 15, 2023, 12:54:12 PM
I agree.
Post by: snowshovel on June 24, 2023, 01:32:26 PM
This happened to me last year, and the problem was that my fuse went out.   I got replacement fuses on amazon.
Something to look out for is the first time I ordered fuses on amazon for this, the rating stamped on them was not correct, and the fuse blew immediately.  I returned them and got replacements from a different amazon reseller.
Post by: John Rose on December 14, 2023, 09:18:13 PM
(For the RadExpand 5) The discharge fuse is the 40A one (orange?), the charging fuse is 5A (brown? - 10A for a RadTrike). You probably need to replace the 40A one since it appears to be charged up. Pull it and see if the little bridging strip between the terminal blades has a gap or is blackened.
(https://www.shutterstock.com/image-photo/blown-new-mini-fuses-on-260nw-2310961487.jpg)
You should be able to pick these up at a hardware store, or even a gas station, especially the kind that cater to long-haul truckers.
Oh, hey, Rad gives us a fuse replacement guide, with animated GIFs, Lawyerese warnings, and everything:
https://radpowerbikes.pxf.io/752o4d
