handlebar question
Started by VegasSteve, August 07, 2022, 12:07:01 PM
VegasSteve
I'm 6'1" and I find that I am 'reaching' more for the handlebars than I like, prefering a more upright position.  I see some suggest a stem riser, but with the wiring, I can't see how you could gain much that way.  If I could tilt the bar a bit, that might help some, but then the palm rests on the grips would be pointed down.  I can see how to adjust all the other handlebar components attached if I do that EXCEPT for the grips, which seem pretty solidly attached.
Is there a trick to rotating the grips or do you have to rip them off and get new ones?
pchew
Quote from: VegasSteve on August 07, 2022, 12:07:01 PM
I don?t know the answer to your other question butI was able to raise my handle bars with a stem riser without having to mess with the cables.  There was enough give to raise it 2.5 inches (I was able to use all of the inserts except for the smallest one).  Made a big difference.
I can send a pic if you like.
Wake Bike Stem Riser Bike Fork Stem Extender Bicycle Handlebar Raiser Head Up Adapter Suitable for Mountain Bike, Road Bike, MTB, BMX, Fixie (Aluminium Alloy, Adjustable) https://amzn.to/3K7G61K
rjp
You can rotate the grips but they turn pretty hard. Just force them they will turn. Mine did! I used a Delta Stem Riser to raise my stem 4" on my Rad Rover ST 1. Had just enough cable length, no problems, worked great.
johnyj7657
I ordered a jones h-bar 2.5" handlebar for mine.
Supposed to have a 2 inch rise and better shape for upright riding position
I'm 6 ft 3 and the stock bars are just a bit low.
If the h-bar is still to low I'll use a stem extender but gotta wait for the handlebars
Radio Runner
Is there a "trick"?
Yes. The trick is an air compressor. Jam the nozzle under just the edge of the grip an blast away. This is what bike shops use for install and removal.
VegasSteve
Quote from: Radio Runner on August 07, 2022, 10:10:38 PM
Is there a "trick"?
Thanks for all the replies.  I had my bike checked out at the local shop and had the guy order me a stem riser, so that should do it.
Zeeman
Thanks every one for all the great info, Im going to try a few suggestion you have all provided and see which fits me best.  I just joined, got a rover 6.
johnyj7657
I put the jones handle bars on but had to add a 110 mm adjustable stem to raise it.
I like them.  But I think I might need them another inch higher.  But I'll have to swap the front brake line out for a longer one.
Just gotta look up what connector the brake lines are.
g33kyfr34ky
#8
My solution, ape hangers. Super comfy. You will need to lengthen brake hoses, derailleur cable/housing and electric cable extensions.
Mooree
#9
After reading some of the reviews of buyers on Amazon, I wasn't sure what to expect but I was impressed with the REDSHIFT road bike stem road bike stem. At the end of the ride, gone was the numbness in my hands, and there was much less fatigue in my arms and shoulders. My ride is broken up into sections of trail, and one telling aspect of the ride to me was that after finishing a section. https://biketoworkday.us/best-road-bike-stems/
