Replace hubmotor connector on 2019 Radrover
Started by Mtolesen, August 03, 2023, 09:41:50 AM
Mtolesen
Hello, the male connector for the power to the hub motor on my 2019 Radrover, has been ruined due to overload, does anyone know if somebody has ever replaced this connector, and if yes, do you know where i could find a link?
You can see the connector on the picture.
I found a couple of youtube videos where somebody opened a bafang hub motor and soldered in a new cable. It looks challenging.
Today, JimInPt showed that Amazon has extenders for 9-pin motor cables. Cutting one would produce a motor cable.
Is the controller side of the connection bad, too? I think soldering a new cable into a controller could be worse. I might buy a new controller.
Mtolesen
Hello handlebar, yes, you are right, it could be the solution.
Do you know if there is a drawing with wiring color code, that shows how this plug are connected, and are the colors of the wires, standard in this kind of plugs?
Also, do you think you could give me the link to the Amazon page with the extender cable?
#3
Quote from: Mtolesen on August 04, 2023, 09:55:16 AMAlso, do you think you could give me the link to the Amazon page with the extender cable?
Here you go: https://amzn.to/47D5s2R
If you search for "ebike cables" or similar you can turn up other vendors and cables as well.  Hope you find one that works for you.
https://www.youtube.com/watch?v=HFrACMSy5-w&t=190s
https://www.youtube.com/watch?v=a1WiPkiwGKk&t=1294s
The color is the easy part. These guys leave lengths of the original wires when they snip them to pull out the old cable.
If you just need to replace the connector, maybe you can make your splices between the new connector and the axle, using heat shrink tubing over each solder connection, and for support taping the whole thing to the chain stay (instead of just using a couiple of zip ties). I'd use better tape than duck tape.
