Rad City rear noise
Started by MichiganRadRider74, May 01, 2021, 06:56:15 AM
MichiganRadRider74
I have a 2020 Rad City with a noise I can't diagnose. It is a cyclical noise from the rear. It is there all the time while riding and not associated with pedaling.  I applied light braking and it still occurs. I put the bike on a rack and it is not heard with the motor turning with or without pedal turning.  Only seems to happen with my weight on it when riding.  I don't see any obvious clearance with the rear fender, but sounds like something is rubbing somewhere!  Any advice appreciated.
Veggyhed
If it's happening with weight on the bike I would check to make sure that your spokes are all tight. Remember to evenly tighten the spokes if you're going to do this so you can keep your wheel true
MichiganRadRider74
Thanks I will look into that
MichiganRadRider74
I did find a few loose spokes but was sold the wrong size wrench so will return the wrench and get a 4.4mm one and report back if this solves the problem.
Veggyhed
Ryan has a video somewhere on here about tightening spokes.
Please let us know if it was your spokes
Here is the video on tightening your spokes (don't judge the quality though  ;) they are much better now): https://youtu.be/fqZQ-HYLFw0
MichiganRadRider74
I tightened the spokes and also adjusted the inner brake pad as I heard a high pitch squeal. It was raining here today but I rode it up and down my street and did not hear the noise as before.  I will have a longer ride this week, but it appears I have solved the problem.  Thanks so much all who contributed.
MichiganRadRider74
 :). It worked!  Took a 30 mile ride today and no more noise!  Tightening the spokes and adjusting the brakes resolved the issue.   Thanks to the forum for the answer
Veggyhed
Awesome.
