rad 750 watt motor gear ratio
Started by ejonesss, August 29, 2020, 09:48:12 AM
ejonesss
i know that the radwagon 4 is not out yet but other rad bikes i assume use the same hub motor so does anyone know what the reduction ratio of the motor is?
also what motor do they use? are they just relabeling 8fun/bafang motors like the voltbike mariner bikes do?
i am thinking i may have to add a mid drive like the cyclone original 48 volt 1600 watt version.
if the motor is the same bafang then it is possible that the freewheel mount could be sheared off by the torque so i may have to use the brake disk mount instead as they are stronger.
Rad uses Bafang motors on all models except the RadCity and the RadMission (not sure what the RadMission uses). The motors are 5:1 planetary gear reduction.
992023515
From the rad wagon page:
Hub Motor
Geared Hub Motor with 5:1 Planetary Reduction
Looks like a rebranded Bafang motor but till we get someone who has one reporting we won't know the specifics of the motor
ejonesss
what bafang hub g310 or 311 and can it be opened up without unlacing the wheel also has anyone worn out a gear cluster or clutch?
You can remove the motor components without removing or unlacing the outer casing.
