Radrunner 1 max speed
Started by Josh Hixson, May 24, 2020, 09:24:44 AM
Josh Hixson
Has anyone figured out how to increase the max speed on the Radrunner 1, WITHOUT buying the radrunner upgraded display (since it's both $99 and currently out of stock). Is there a way to do it without the upgrade or is there an aftermarket ebike controller that will work? Got a few long country roads I'm anxious to fly down!
Bolton ebikes is going to be your best bet: https://boltonebikes.com/collections/motor-controllers-and-displays
You get the screen and then you can push even more than 750 watts to the motor if you choose. Let us know if you decide to go this route.
Josh Hixson
Thanks Ryan I'll check it out!
JWilson
You can increase the speed on the Runner by eliminating the speed control input. To do that you can clip the small white wire that runs between the controller and the motor. I've done this and so far my max speed on a flat surface is 24 mph. I have a picture and will try to figure out how to include it. I'm new here.
Josh Hixson
Sorry I just saw your post! (I'm also new here :-) Thanks for the tip. I'm a little nervous clipping wires, so a picture would be helpful.
Quote from: JWilson on May 28, 2020, 09:23:14 AM
Hey JWilson - good tip for those interested. I find using the Tapatalk app for your phone is the easiest way to upload pictures to the forum.
Steph Kss
Hi
Would be also interested to know how to remove the speed limit on my runner.
Can't find the white wire you're talking about
Thanks
Quote from: Steph Kss on June 06, 2020, 06:10:45 AM
Hi
Thanks
My understanding is that the white wire is part of the group of wires seemingly running as one cable from the motor to the controller. So you kind of have to slice it open to find it. I could be wrong here so proceed with caution. Someone else can confirm.
Steph Kss
Thanks
JWilson above mentionned he has done already this.
JWilson,
Can you share a picture here?
Thanks
