Rad Wagon DIY Passenger Seats with Backrest
Started by cheap shot, October 07, 2020, 06:19:28 PM
cheap shot
Finished product:
Materials:
Seat https://goto.walmart.com/c/2586673/565706/9383?veh=aff&sourceid=imp_000011112222333344&u=https%3A%2F%2Fwww.walmart.com%2Fip%2FBike-Rear-Seat-Kid-Bicycle-Bike-Rear-Handrail-Armrest-Child-Carrier-Bike-Back-Seat%2F165311057%3Fselected%3Dtrue
Knobs and bolts https://amzn.to/3iXPgyK
Roll of neoprene https://amzn.to/372iF8t
Pressure treated wood for seat board and locking block
1 nut to lock knob bolt in place to prevent the bolt from spinning as you tighten the knob
Adhesive to attach neoprene to seat board
This is very much a BETA product, and I can already imagine some improvements.  However, think of it as something to get you started thinking about your own project!
Step 1:
Cut a wood board to fit under the seat.  I used similar dimensions to the deckpad but also made it match a bit more to the seat frame (6 3/4 x 11 3/4).  Cut a similar shape of neoprene for cushion between the board and the bike frame.
Step 2:
Take apart the seat cushion from the seat frame.  The seat should come with some longer screws that you'll use instead.
Step 3:
Drill holes into the board for the two screws that attach through the seat frame to the seat cushion.
Drill a hole in the center of the board for the tracking knob bolt to slide through.
Step 5:
Cut a small rectangular shaped board that will be used with the knob to secure the seat to the frame using the yepp seat mounting rectangle (3 5/8 x 2 1/4).  Feel free to sand the edges as it fits a bit better if it is rounded due to the welds of the frame.
Step 6:
Dry fit everything, make any adjustments as needed, and then paint.  Attach neoprene to board with adhesive.
Step 7:
Attach the seat: https://youtu.be/x5NO0e0bIuc
Step 8:
Ride rad!
