RC5 Battery mount
Started by Franklueck, October 06, 2024, 07:39:51 PM
Franklueck
Has anyone else had issues with the Battery mount plate causing powerless to the motor and PAS?
I had an issue with a Rover 5.  The wiring in the cradle is thin so high current melted the insulation.  It expanded the cradle battery input connector.  It made the battery difficult to remove.  I had to replace the connectors on the cradle and the battery.  They were slightly different size though they looked the same.  So both sides I had to replace.  It was an easy replacement.  Solved the issue.
My power issue was no power from the motor or no power from the battery to the LCD.  Sometimes I had power and worked for a few minutes sometimes not at all.
