Bike won’t turn on
Started by Rickesco, June 25, 2021, 11:42:20 AM
Rickesco
Hello,
Has anyone had the issue of the bike not turning on?  Battery has full charge, I turn the key and nothing. I've followed the troubleshooting guideline and still nothing. I appreciate any feedback
The first thing to check is the 40A fuse in the battery. I would check the voltage at the battery terminals to at least determine if it is the battery or the bike.
jbfoster
I had a issue like this last year. It was the silver connecter near the display. If not check all connecters.
Jim
Which bike model do you have? If it is the RadMini, I found that the display connector under the main tube (the 2nd one, not the silver one up top) can get disconnected when unfolding. If all your connections are secure, check the fuse (you have to dig out the rubber cover with a small screwdriver or other tool). If you want to test the battery, remove it from the bike and use a voltmeter on the two large outer connectors. A full battery should read about 54.6 volts, but remember to turn the battery on with the key. There is also a large connector on the bike that connects the battery to the controller, and that's the main power line.
RobtRoma
I also had the connector under the display disconnect.  I had just started a ride to work.  I pulled over to zip up my vest and when I went to continue the ride I had no power.  I left the bike and took my car to work.  When I was finally able to do some research and check things, it was that connector under the display.
