Discuss 2019 Rad Power Bike Models
Started by Ryan, December 05, 2018, 04:44:20 PM
Last year when I saw the changes coming to the 2018 Rad Wagon I knew it was worth the wait to get the 2018 versus the 2017. I do like some of the changes coming to 2019, mainly the new tire liners and moving down to just a 7-speed (at least for us). As a 2018 owner I am very glad they kept the same battery and I expect they will make more significant changes in 2020.
Psuggmog Volbenz
I ride a 2018 Radwagon and often carry heavy loads.. I ride in a very hilly coastal area and ride about 95% of the time without using electric power. One of the essential features, for me, is the 21 speed gearset. I try to maintain a constant cadence when I ride. This would not be possible with a seven speed radwagon the way I ride. To me, the reduced gearset on the 2019 Radwagon is not an improvement.
RadBiker
Quote from: Psuggmog Volbenz on December 05, 2018, 08:41:23 PM
I also live in a hilly area and do not carry a lot of weight. I seem to use only  a few gears always and adjust the power when I need a bit more help. The gear changes are not always super smooth so I try to avoid changing them excessively.
Rjbur007
Exactly why I bought the 2018 RadWagon and tilted my head when they market a reduction in gears as a new feature?   My shifting has been very smooth thus far.   If anyone is having shifting issues, then have a local shop time your bike... I assembled mine and I seen had to spend a little time with my front
Derailleur. Rear was fine.
schwutke@gmail.com
I am contemplating to get a RadCity.
I am a little bit concerned about the frame size in 19in, which is the same as the smaller frame, when I compare dimesnions, s.a. reach, wheelbase, etc..  Only Seat post and handlebar height are different.
I would also prefer a bigger wheel diameter, s.a. as a 29er or 27.5. (My previous MTB was agile with a 26" wheel but not very stable at higher speeds.) Any information if increased wheel diameters are planned for the next generation bike?
Quote from: schwutke@gmail.com on June 29, 2019, 05:09:55 PM
What is your concern with the 19 in? As far as I know this is how all bikes are sized with the longer seat tube. I haven't seen an instance where there wasn't a Rad bike that would fit someone. I doubt they will go with larger diameter tires, though if you're looking for stability perhaps the Rover or Mini would be a better option. I'm 6ft and my wife is 5 ft 5 in and we both fit our Wagon without any problems, simply have to adjust the seat height.
