Best bike lock for Mini st2?
Started by Windward, September 18, 2021, 05:55:51 AM
Windward
Opinions on the convenience, usefulness and protection level for BORDO GRANIT X-Plus™ 6500 and other locks. If you have a st2, how/where do you mount your lock while riding?
Below is a photo of how I mounted my Abus GRANIT XPlus 540 u-lock to my rear basket - it's the only place on the entire MiniST's unique frame that works (the ABUS cable is for occasional use around trees and the like).  I know the 6500 is a folding lock, but may have a mount included for attaching to a frame bar like mine.
I think the 6500s are typically mounted to water-bottle stud locations like the ST's front downtube; you can also buy adapters to mount water bottles to the front-rack interface; I have one of these to hold two bottles and you could mount the 6500 to one side: https://amzn.to/2ZkSjwI
When I was researching locks, I found more than one video showing how to blow the 6500 apart at a folding joint (just like all the other folders), so I went with the u-lock design instead, and the 540 costs less as well.   It's certainly bulkier and heavier than the 6500, but in this location is completely out of the way yet easily accessible when needed.
If you're not in a high-crime area, the folders are probably a great option.  I live in a peaceful little town in the woods, but my recovering-engineer OCD wouldn't let me get the 6500 I originally wanted after I saw it defeated with a little horsepower.
Windward
Thank you for your very helpful reply @JimInPT! The photo helps to understand how this all works. When you lockup your bike, do you have much trouble getting the frame of the bike and the bike rack bar all within the "U"? Do you have to take the battery off to successfully lockup your bike?
#3
Quote from: Windward on September 20, 2021, 04:22:23 AMWhen you lockup your bike, do you have much trouble getting the frame of the bike and the bike rack bar all within the "U"? Do you have to take the battery off to successfully lockup your bike?
No trouble locking the bike's frame to bike racks and other things so far - there are several points on the frame that work well, depending on the height and shape of the rack, but I also bought the long version of the 540 (300 mm shackle) for exactly that reason, because e-bikes tend to be somewhat bulkier and heavier to position in place than standard bikes.  The extra shackle length makes that a lot easier and as you can see in the pic is about the same length as the rear basket, so it tucks right in.  But I do have to put the bike up next to the rack even so, although not touching.  I carry that cable for situations where it's not possible to use the U-lock directly, like with a tree or too great a distance from a rack.
As for taking off the battery, no, I never have to remove it to lock it up.  But what's not shown in that pic is a mod I made to add a separate small u-lock to help protect the battery itself (see pic below) - if you're not aware, you should know that all current-gen Rad batteries (except probably the new Rover 6) can be unlocked and removed with a blank, uncut key available easily on eBay.  I carry a blank on my keyring to show other Rad owners, because they find it very hard to believe.
The extra u-lock deters battery removal.
Windward
The secondary battery lock is a great trick! Do you leave the lock in place while riding?
Quote from: Windward on September 21, 2021, 12:25:59 PM
Yep, in fact I never bother to remove it now; switched to charging the battery on the bike to keep it simple and easy.  The lock doesn't get in the way of anything and the extra weight is negligible, especially compared to all the other stuff I've hung on the bike, including my fat ass.
Joel52334
I kind of went overboard with security devices.  I probably have the only Ebike in my county.  "Is the Heaven?  No, it's Iowa!"  I wanted to have "a full package" a solution for many environments.  I have the ABUS 6500, the long reach U lock.  The 50# ABUS chain, the Abus Chain lock, brake disk locks.  I have the saddlebags, and you can mount stuff EVERYWHERE on an RW4.  I have most everything "mounted" but for the MEGA-CHAIN!  I'll take some closeup photos.  I'm accessory enriched!
Windward
Very helpful contributions in this thread. Thank you all :)
Joel52334
#8
I put the Giant ABUS U lock on the side of the rack on my RW4.
Quote from: JimInPT on September 19, 2021, 11:43:50 AM
jerrygno
For the person who put the u lock over the battery, can you let us know what lock it is or its size? Its a great idea I want to try.
Quote from: jerrygno on March 09, 2022, 07:03:40 PM
Hi, that would be me.
Here's a link to a post I wrote up last summer going into detail about it.  Note that this specific arrangement might only fit the MiniST2 due to frame geometry.  Let me know if you have any questions.
https://www.radowners.com/index.php?topic=158.msg5317#msg5317
Cheers!
Windward
To Jim's earlier point,an etsy seller is offering to sell extra keys that fit all rad power bike batteries.
www.etsy.com/listing/831758108
Quote from: Windward on March 10, 2022, 03:34:51 AM
That's the right part, but a pretty-high price being asked.  Here's the key on eBay for less, with several other sellers as well:  https://www.ebay.com/itm/254723401907
I couldn't find it locally at the hardware store, so I went to eBay last year and got it for about US$8 delivered - here's the part you're looking for; it's a Honda motorcycle blank:  X84 or HD74
