Upgrades
Started by Ummad Aslam Butt, December 02, 2020, 07:06:30 PM
Ummad Aslam Butt
Let's talk about upgrades you have done to your mission.
msl
I'm putting a softer seat on. But what I really wish my Rad Mission had is shocks.
Is it possible to do that? Anyone know?
wkindred
Quote from: msl on December 28, 2020, 12:43:04 PM
you may be able to upgrade the front fork with a suspension fork from bolton -
https://boltonebikes.com/collections/frames-and-parts/products/fat-bike-suspension-fork
you'd likely need the 26" version but check with kyle at bolton to verify...
massassi
You or the LBS should be able to do that. I'm in the process of adding shocks to my radwagon. The problem with it is that the head tube is extra long so "standard length" steerer tubes don't fit. The website pics make it look like these are the same between the two models. So I would be careful
MyTill
wtfg
I installed a RockShox Recon Silver RL on my Rad Mission
It works good!!!
Installed the 27.5 100mm 9x100mm 42mm offset 160 disc brake
I had to install spacers on caliper otherwise easy upgrade.
hot rod
      I appreciate your response of:   I installed a RockShox Recon Silver RL on my Rad Mission
It works good!!!
      Kinda pricey, any idea where can I find a less expensive fork/shock set up?
Spoonbender
#7
Quote from: hot rod on September 12, 2021, 08:25:39 PM
It works good!!!
I put these on from Amazon. Bucklos 27.5, a lot better ride now.
Ride every day you can :)-
whoosh
#8
Quote from: wtfg on August 13, 2021, 01:32:22 PM
It works good!!!
Congrats! 8)
Is this the one? RockShox Recon Silver RL Suspension Fork | 27.5" | 100mm | 9x100mm | 42mm Offset https://amzn.to/3TduBc8  I didn?t see any reference to the 160mm disc rotor size.
What specific spacers did you use?
Were you able to source a fender that would work with this shock?
I am thinking of the Recon, I know some installed the rockshox Judy ? any reason you didn?t go with that one?
Did you pay $260?  ty
Hama
Quote from: Spoonbender on October 19, 2022, 11:34:32 AM
It works good!!!
Was it a direct fit?
