35 amp controller upgrade in the U.K.
Started by Tony, December 14, 2020, 12:18:25 PM
Quote from: Tony on February 28, 2021, 06:56:21 AM
Any more thoughts on the delayed pedal pedal assist ?   Tony.
Since your P4 and C4 are set to 0, then those are not causing the delay. Take a look at C1 which is the cadence sensor sensitivity. If yours is set to 3, change it to 2.
Tony
Thanks for the suggestion. My C1 was set to 4.  I changed setting to 3 with no improvement and making the Speedo erratic at low speed. I changed the setting to 2 resulted in no pedal assist, still with erratic speedo. Seems these changes were making things worse so I changed C1 to 5. This is much more responsive with pedal assist engaging almost immediately. Just posting this to say thank you Altema for suggesting where to look, and it may help others. Tony.
Jimlad
Hey guys I am in UK (Southampton) and also have the 35 amp kit fitted on my rad wagon 4. It sure does shift. I am thinking the branded 250w motor never was 250w and more restricted for the EU
Tony
Yes the Euro 250 motor isn't the problem, as it seems to be capable of producing up to approx 1500 watts with the 35 amp controller. I think it was Altema that mentioned some time ago the standard controller was the restriction. In our case restricting us to 250 Watts.
Jimlad
It was painful to use before the upgrade. Hitting 16mph and feeling like someone breaked for you.
Like a new toy now !
I need to make a bracket for the 35a controller what have others done ?
Tony
I have a Rad Mini 4 but I think Ryan did a video fitting for the Wagon
