Bafang G063 1000 watt motor
Started by Tony, June 14, 2023, 11:11:57 AM
Wattsunlimitedmbs
I have my G063 with 11 pin connector working great with the Area13 RR6+ v2.1 kit. I had to update the speed signal settings but have about 50 miles on the set up.  8)
Tony
Tony
Quote from: dkrout on September 20, 2024, 10:49:58 PMG62 1000W works great.  I did my usually 16 mile (each direction) commute all week. It definitely out performs the G60 750W.  It had maybe a 2-4 mph bump across the board for all the PAS settings, it has more torque so handles hills and wind much better.  In general it is an improvement over the 750w.  The main reason I got the G62 was so that I could run the 35amp controller with the same settings and not burn out the motor (I burned out 4 G60's over the past few years, long story).  Still need to do more long term testing, but I think I will be good to go.
What bike did you fit this on, and what plug connections did you use. ?
dkrout
JTK77
RadMonster with modded G062. 60v battery with 40% SOC. Still plenty of speed 😅
https://youtu.be/yNqTIDrea7c?feature=shared
