Radcity 3 front and rear lights not working
Started by bwhicher, February 29, 2024, 09:29:53 AM
bwhicher
My RADCITY 3 front and rear lights stopped working. Rear light brake light works
I recently had this same failure on my Rover 5. Inside my controller are two auxiliary circuit boards in black shrink wrap. One is circled in green, the other is below it and to the upper left. One board is for the headlight/tail light and one for the brake light. I replaced it with a used board from a Facebook group member's controller, which he kindly removed from a non-working controller. My tail light was also dead; I don't know if it failed and took out the auxiliary board or vice versa. I replaced the tail light with an aftermarket one.
bwhicher
Quote from: DickB on March 01, 2024, 03:19:01 AM
Doesn?t look easy to change.
The easiest option you have is to replace the controller.  If you are going to do it, then go with an upgraded controller to 35 amps. It will give you more power and some extra speed.  Area 13 has them usually in stock.  You will also get an easier to read color LCD screen.
