New PAS sensor for a RAD Rhino (Rover) from 2019
Started by Mtolesen, July 15, 2024, 07:34:56 AM
Mtolesen
Anyone know where i can buy a replacement PAS sensor for my Rad Rhino (Rover) from 2019, in Europe, i think it is broken?
Try ebay or amazon.
Are you missing magnets? Are they clean? What are your symptoms?
Mtolesen
hello, actually it is not the palstic disk with the magnets i need, it is the little sensor with the magnet sensor and the yello inside plug, i need to replace, the one that reads the magnet pulses from the plastic ring with the magnets.
Is it inside the controller box? or the one attached to read the magnets?
Mtolesen
It is the little reader, with the red LED that sit next to the plastic disk with the magnets, thats called the PAS sensor, and a wire with a small 3 pin plug comes out of it.
Thats the one i need to buy somewheree, but where?
Tony
I replaced the one on my Rad Mini 4 2019 with this from Amazon. Bike Pedal Assist Sensor, Multifunctional 12 Magnets Dual Hall Electric Bicycle Pedal Sensor for Electric Bikes, Electric Bicycle Assistant Speeds Sensor PAS System Bike Cycling Accessories
Quote from: Mtolesen on July 16, 2024, 06:20:27 AMIt is the little reader, with the red LED that sit next to the plastic disk with the magnets, thats called the PAS sensor, and a wire with a small 3 pin plug comes out of it.
Probably you may need to contract RAD for the part.
