Radrunner headlight and tail light upgrade
Started by brian7588, July 22, 2024, 01:05:35 PM
brian7588
I am working on a 12v converter for a headlight, tail light and signals. What kind of mounting bracket should I look for the front post threads? Photo
This is the headlight
MGLLIGHT DOT 7 Inch LED Headlight Motorcycle Blue Halo High/Low Beam, Motorcycle LED Headlight Projector Angel Eyes Light JK LJ CJ Headlamp Replacement, 1PC https://a.co/d/1PsDuJF
Also, how are you guys mounting your tail light and signals?
BlyilyB Motorcycle Blinkers Indicator Sequential Turn Signal Amber LED Lamp (Pack of 4) https://a.co/d/fC6YZBV
Have you upgraded the controller?   If so it may cause problems and has been known to burn up controllers.
If not contacted RAD about the upgrade.  It might not be compatible.
brian7588
I have an upgraded controller and a 12v converter. I just don't know how to attach the new lights.
I highly recommend you contact where you purchased the controller from.  They may advise you not to upgrade your lights.
As your picture shows. The front mounting bracket I'd a good place to mount your headlight. Amazon has a lot of headlight brackets.
Quote from: brian7588 on July 22, 2024, 01:05:35 PMThis is the headlight
From the pictures it is cool looking headlight but it looked like is an insert. I think it was meant to replace the original headlights. Unfortunately it did not show the energy ratings. Also the warning "Frequently Returned Item" is a big flag that maybe it lack product information or instructions?
Headlight case. https://a.co/d/4FPP4JE
Not to discourage you. In the early stage of me owning an ebike. I was thinking of modding my headlights. But I abandoned the idea when I read about the others having electrical problems with their controllers.
I do not ride much at night so I have resigned myself into using a flashlight strapped to the handlebar. It is a lot brighter than stock headlights. https://a.co/d/6cIcq8J
